aldiaz
10 points
Posted on - 04/13/2012
I've been wanting to clean the keyboard of my laptop but I don't have an idea how.
I need the experts tips on this to avoid damages to my laptop.
Could anybody please tell me the proper ways on cleaning my keyboard.?
I would really appreciate your help on this.
Thank you so much.
nigar100
Proper Cleaning of my Laptop’s Keyboard
Here is the solution:
Before you start cleaning your laptop's keyboard,make sure it is unplugged and powered off. Also remove the mouse,any disc or CDs,USB drives and anything else that is protruding from your machine.
If you have elected to take the easy road and leave the keys 0 attached to your laptop, you can clean in between them by using a can of compressed air.If you have decided that you would like to take off the keys, use a knife or similar object to gently pop them off. At last you may also spray any nook and cranny type areas with the compressed air.
I hope it will solve your problem.
