Proper upload after descargar midi ox
I am having difficulty with uploading a preset to midi ox. Had read carefully instructions but of no luck really.
Can descargar midi ox banks, presets and update firmware. Â But having big problem to transfer from ax to midi ox.
Midi ox shows 0 bytes received and was never impressed. Does the port routing in midi ox has something to do to receive files? Â Does blocks and IR gets transferred from axe using midi ox. Was descargar midi ox was a failure on my part?
I am very hopeful that this will work soon for me.
Any help would be much appreciated.
