Pros and cons of converting XLS files to PDF and PHP
I have a ton of excel files and I need to convert them into PDF or PHP files. I need to know which file type would be better because it might be costly to convert the excel files into both. So, could you please tell me the pros and cons of converting xls to pdf con php? In addition, some instructions on how to easily convert them could also help. Thank you!
Answered By 0 points N/A #134468
If you want to convert “excel files to pdf” you can easily convert it by softwares like “pdf converter”. If you want to convert “excel files to php” you have to convert it first in “html” then “html to php”. If your excel file’s contain any spreadsheet by converting it into "php" you can make a dynamic web page and can communicate with user’s but converting “excel to php” is a complicated process as it have to converted in “html” first . So, I suggest you to convert “excel files to pdf” which could be easily done by “ pdf converter”. You can download the software free from internet
