Pros And Cons Of Easy To Use Database Software Free
Hi. I want to install database software in my PC. However, I am confused about the software which should be installed. So can you please suggest me the advantages as well as the disadvantages of some of the easy to use database software free so that I can decide which one out of them to use? Thanks in advance.
Answered By 120 points N/A #95754
Hi. The advantages as well as disadvantages of some of the easy to use database software free are as given below-
1) CURBID
It uses the language C and is open source software.
Pros-
• Three-tier architecture
• Supports horizontal as well as vertical scalability
• Reliability and operability
• Data replication and consistency
• Backup
Cons-
• Language barrier
2) MySQL
It was found in 1955 and is open source.
Pros-
• Compatible with all OS and supports both C as well as C++
• Can be used when there is unavailability of network
• Provides security through encryption
• There can be alignment with the users by changing the time zone of the server
Cons-
• No longer an open source software since it was bought
• Cannot use the members of its community to resolve errors
3) MariaDB
It is used by Wiki, Facebook and Google. It has been developed by the developers of MySQL.
Pros-
• Provides scalability and also offers integration
• It is easy to install and use
• Since it was developed by the developers of MySQL, it has all the essential properties offered by MySQL.
Cons-
• Security is a concern
• No proper interface provided
• Absence of password complexity plug-in
