I was looking for a software that will control the usage of USB drives. I found this freeware 1st Disk. But I would like to get some feedback first before downloading and using it. I don’t to waste time downloading and installing something that will not be useful later on. Please comment on this software and its pros and cons.
Thanks!
Pros and Cons of using 1st Disk Drive Protector Software
How are you doing?
So far, the 1st Disk Drive protector has received many positive reviews regarding protecting your removable files from unwanted users. This is very important in providing security to your important files away from a person who may misuse your data.
Overall, the software can be a good part in your file security. You can also make this invisible disabling other to access it.
Diane
If you carry sensitive data in your USB then you must need to install this software to protect your system form unwanted users so your data is secure and no one see it without your permission. There are positive reviews for such software because it really helps in securing your digital data.
Smith Thompson.
