Pros and cons of Vertex Plus Drives?
I have been contemplating for some time about upgrading my computer system (PC)hard disc drives.
I recently heard about Vertex plus.
I would like to know more about Vertex plus, its pros and cons, system specifications, compatibility with windows XP, anything I need to know, before I do the upgrade without having any regrets later.
Answered By 0 points N/A #138952
Vertex plus is a product of company name OCZ Technology Group Inc.  Vertex plus is one of the reliable and faster Solid State Drives (SSDs). Solid State Drives are different from traditional rotating magnetic hard disk drives.   SSDs are the new innovation of the traditional hard disk drives.
There are different types of Vertex Plus products.  Their major hard disk product categorizes are Solid State Drives and Hybrid Solution hard disks.
Hybrid solution Hard disk is a combination of both traditional hard disk method and SSDs method.
First you must identify what type of hard disk you need (SSD or Hybrid one)
Then you should identify your computer motherboard specification for the hard disk drive (EX: SATA/ SATA 2/SATA 3)
Vertex plus Hard Drives are supporting for windows XP versions and you can buy it from different sizes.
Thank You,
John major.
