Pros and Cons of Vizioncore VRanger pro 3.3.0.2
Experts! I want to hear from you guys about Vizioncore VRanger pro 3.3.0.2. I need to know some pros and cons from the end user. And suggestion will be very much welcome. Thanks.
Wassup Skylabreonna, I think I can help you in solving of that question that you have asked. The Vranger Visioncore is very important in that it is the recognized industry standard backup and restore solution for virtualized environments.
It is sold at an amazing price and also offers outstanding features for its price. It is also easy to use.
It uses a centralized GUI, it has VirtualCenter integration and easily engaged configuration options that allows any level administrator to go from download to backups in minutes.
It also includes a VSS driver that utilizes Microsoft's Volume Shadow Copy Service to pause application writes.
It provides VSS quiescing for VCB backups. This feature enables quiescing of supported databases to provide a "transactionally consistent" backup image that can be used to recover the application as well as the image.
Visioncore vRanger can also configure backup jobs for a physical server with just few clicks and does not have any disruption.
It has integration in that it follows virtual machines after they perform the regular scheduled backups of the computer.
I hope this solves your query
Thanks
