Is proshow producer program eating my computer speed?
Hey Experts,
                I need some help with my ProShow producer program. I was starting with my project and uploaded some videos and music into the timeline. After a few minutes of editing and motion setting, my computer started to slow down extremely slow. I checked my task manager to see how much memory it was using on my project. When I went to the performance tab my computers usage was just around 50%. What can I do to maintain my computer speed?
Best Answer by arif_ijb
Answered By 5 points N/A #83355
Just simply put the (show desktop) icon in your task bar it will help you……Or try to defragment some of the items from your pc. hope that helps you out…
Answered By 0 points N/A #83356
Hello Hillary,
I have a solution for you . Just get ADVANCED CARE SYSTEM-4 full version . It will help you to fix your problem.It scans your computer deeply and  finds out all the problems which are slowing down your PC and fix them all .That is ,It  helps you to repair, protect ,clean and optimize your PC  which combines Registry clean, defrag,system tune up,shortcut fix, privacy sweep, junk files clean, disk fix, optimization and more which allow you to boost up your system just like a new one. These are the main features of it:  I think it will help you a lot. Thanks
