Protect certain parts of the form in Word 2003
You are required to make a form in Word 2003. You require certain parts of the form to be protected against made by the end user and certain part to be editable.
In word 2003 you can Protect One Page from changes in a Word Document and have the facility to apply the changes on remaining pages.
First of all make the sections in the document.
To protect the pages you have to Insert section breaks before and after each page. If there are more sections to be protected Then do the same for each section.
Click on the tools menu and then protects document. You can edit the restrictions in option available in the menu. Click in the check box of "allow only this type of editing in the document".
Below the fill-in forms box click on “select sections”. Click on each section to protect it in the section box. Then click on “yes, start enforcing protection” and enter the password in giving boxes.
Yes you can protect only certain part of the Form created in a Word document. For this you, the parts that need to be protected alone has to be created in a separate section.
