Protect Data Through Endpoint Protocol Using System Center 2012 Endpoint Protectionand Secure You Are Data.
What is meant by endpoint protection? How can we be securely protected using the system center 2012 endpoint protection?
Endpoint protection is just like the securing the data which have to send through some external application via Internet or web. So, once the data is transferred from end user it should only reach the destination like it was when send. This type of end pint protections is most generally used in the messaging and some other online data transfer applications.
So, if we want our data to be secured using system center 2012 end protection follow these steps and make your endpoint protection ready for you as well as for your clients or users:
Step 1: Open system center configuration manager.
Step 2: choose the Site configuration.
Step 3: In the site configuration, choose the servers and site system roles.
Step 4: select your configuration manager server and right-click on it and click on site system role.
Step 5: Then you will be taken to a wizard namely Add site system role wizard.
Step 6: check whether all your setting is alright and click on the next button.
Step 7: Now click and choose the Endpoint protection and click on the next button.
Step 8: Once you have clicked on that you will show a utility box of license agreement click I accept and click the next button.
Step 9: Now you will have 3 option from the Microsoft where you need to choose that which plan you are willing to use. Select the First one which is the best according to me and click on the next button.
Step 10: Once you have clicked on the next button you can see something installing and once the installation is complete your set with the site system roles and endpoint protection.
You can also create your own endpoint protection rules for your clients and user and also give them alerts when some malicious activities happen with the user or your clients these things comes handy. So, this is how we use and configure our system center 2012 endpoint protection.
