m asad
Posted on - 07/26/2016
Hi.
I was planning on installing an anti-virus in my computer because these days a lot of issues are coming up with it. All the Files and folders automatically open up and close, and the PC works slowly. It takes 10-15 minutes for one File to open. So, I guess it is due to the presence of a virus. Can you please me a way to check my PC for virus or recommend some good anti-virus for the same? Thanks in advance.
Protect my PC: check my PC for virus
Hi.
Yes, these symptoms are of a PC infected with a virus. Let me suggest you a really good anti-virus which is Kaspersky anti-virus. It also provides a security scan. The security scan provides features such as reporting of security status, scanning Files for malware, protecting the PC against new and unknown malware, etc.
In addition to these features, the Kaspersky anti-virus also provides features such as unblocking the PC with has been blocked by a Trojan, providing alert against a malicious website, etc. It will be better if you go with the latter option. You should first visit the website of Kaspersky which is www.kaspersky.co.in. There on the homepage you will get two options, one with the anti-virus and other with the security scan.
You can click on download now or try it for free to begin using it. The OS supported are- Microsoft Windows XP, Vista, 7, 8 and 10. Internet connection has to be present in the case of updates, and there should be Microsoft Windows Installer 3.0 or higher installed. Hope we helped.
