Protect Your Expensive Server Room: Server Room Temperature Monitoring
What is server room temperature monitoring? Why is it necessary? Is it a reliable way for monitoring server room temperature? Water leaks are monitored or not?
As we know that the server rooms are expensive. They contain expensive computers and networking equipment that operate at a particular range of temperature. The optimal temperature approximately ranges from 50 degrees Fahrenheit to 82 degrees Fahrenheit. If the temperature exceeds or falls down, it will lead to failure. So we need a reliable way to monitor those temperature sensitive environments.
It alerts if the server rack temperature falls down or exceeds or when doors are open.
It helps in monitoring water leaks.
