Protocols supported by Miranda IM 0.9.50
Miranda IM which has published under GNU GPL license is an open source instant messenger for Microsoft Windows and supports multi-protocol. It works extremely fast and use a small system resources which can easily be kept in a thumb drive. Miranda IM supports the following protocols below:
Miranda IM first comes with few fundamental features. But it is customizable as it can be extended with over 350 plug-ins now. It has been improved by having new enhancements such as IPv6 support, Gadu-Gadu with added login notifications, language pack support per plug-in and avatar unicode path support.
You can download it here:
And it is completely free.
You are using an older version of Miranda IM. This software was updated to Miranda IM 0.10.8 on October 25, 2012 with the following bug fixes:
This is a free application and supports all versions of Microsoft Windows. This piece of software supports these popular protocols:
Other functions that make the program noticed are its ability to import contacts and messages from Mirabilis ICQ and other Miranda IM profiles, transfer files, or block various contacts. The good thing about multi-protocol IM clients is that you only have to use one application in order to stay connected to the web and with your friends. Miranda IM is one of the most complete instant messaging tools available. Even if it isn't perfect and can get you mixed up in the number of available options, Miranda IM certainly deserves a try. You can get Miranda IM 0.10.8 from Softpedia® – Updated one minute ago | Miranda IM 0.10.8.
