Protools 10 always rescan waves
I am facing a problem, it is that protools 10 always rescan waves. Who can help to resolve this issue?
Thanks,
Thanks,
A lot of users have issues with Protools and Waves. Protools assume that some of the files of Waves are infections. So, it keeps on scanning the wave program on your computer. To fix the issue, you can open your Protools application and go to its settings. You’ll see an option to exclude items from scanning. There you can manually configure Protools to avoid scanning the Waves application. This should fix the issue on your computer.
Just in case if the issue does not get resolved, try updating the Protools to the latest version on your computer.
Thanks and regards,
Skarbos Jay.
