Provide me some samples of adobe reference stamp
I need to create custom stamps in different formats to PDF format.
Can I create adobe PDF stamps with Acrobat 9.0?
Can you provide me some samples of adobe reference stamp?
Hi Julianne,
Hope you are doing well. You need a custom stamp in different formats in PDF format. Yes you can create adobe PDF stamps with Acrobat 9.0 easily.
Please see this link to get tutorial.
Please visit this some of link to get samples of adobe reference stamp. Link 1, link 2, link 3.
Have a nice day.
Thank you.
Kknisely Kate
Hello Dear Friend,
The PDF provides us with some tools to create the custom stamps in Adobe Acrobat 9.0. Custom stamps can function like a physical rubber stamp on our electronic documents. You can create many types of custom stamps, such as the date stamp, the number stamp, the name stamp, or the logo stamp.
You can also use your custom stamp as a seal of approval much like an actual rubber or physical stamp. You can create a stamp by following some simple steps. Check this website to see all the steps.
The link below outline another method creating the custom stamps in Adobe Acrobat 9.0.
You can also watch this video.
Hope this will help you.
Good Luck!
