Provisioning services target device software failed to install
I was trying to install Citrix Provisioning Services Target Devices 64 bit program but I received the following error message saying “The application has failed to start because its side-by-side configuration is incorrect”. Is this connection problem or anything else? I attempted all correctly so why this error come? I want to remove this immediately so please provide solution.
Thanks in advance.
File:.CAProcess.cpp Function: InvokeExe Called: CreateProcess Line: 70 failed with error 14002-The application has failed to start because its side-by-side configuration is incorrect. Please see the application event log or use the command-line sxstra…
