Hello! So I have this question. We all know ps2 cannot run ps3 games because ps3 disks are BluRay and ps2 disks are not. But can we run ps3 games on ps2 if first we obtain an ISO image of the ps3 game, after that burn it on a DVD and then put it in ps2. I think this should work, waiting for an opinion.
PS3 games on PS2 possible?
Yes, you can run the “PS3” games on the “PS2” by making the ISO image of that game. “PS3” games can now be burnt to DVD-R discs, BD-R discs and DVD+R DL discs for the making larger size images. There are some requirements to make ISO image of “PS3” games to run on “PS2”, which are as follows:
· Your “PS3” console has Jailbroken system.
· The minimum version of “Backup manager 1.0” should be installed.
· Should have “External USB Had Drive”.
· The source of the image should be “Imgburn”.
· The “PS3” game “CD” should be original to convert to ISO image.
Hope this answer will help you a lot.
