PS4 does not accept game discs
I am having some issues with the disc player of my PS4.
The last disc I removed was fine, but the PS4 beeped a few times. Now, when I try to insert a new disc, it makes noises like it is trying to eject something. There is no disc in the device, but I cannot insert a new one.
Is there a solution that won't require me to have it repaired?
Best Answer by Marende Leen
Answered By 0 points N/A #140107
This is because your PS4 needs a reconfiguration in database. But first Unplug the Power cord. Touch the Power button several times until it beeps (static electricity?!). Turn it on check it if it`s working or not.
If you still have this problem then run your Ps4 in safe mode and choose rebuild database and then you will not face this problem but if your PS4 still have the same problem then you call Sony PS4 helpline.
https://support.us.playstation.com/s/?language=en_US
Answered By 0 points N/A #140108
This is because your PS4 needs a reconfiguration in the database. But first unplug the Power cord. Touch the Power button several times until it beeps (static electricity?!). Turn it to check it if it`s working or not.
If you still have this problem, then run your Ps4 in safe mode and choose to rebuild the database and then you will not face this problem, but if your PS4 still have the same problem then you call Sony PS4 helpline.
