I have issues getting open NAT for both my Xbox one and the PS4. My settings are Modem>Router1 (Router2/Router3-Bridged)>Device. I have done restarts after applying settings but it still doesn’t work. I do not think it is a problem with the LAN since my addresses are okay. Help me get my device working correctly. Thanks
PS4 & Xbox One NAT issues
To get open NAT on your router, you need to create Port Forward. Open ports are used in the allowing connection on your home network from the Internet, and are commonly used in gaming and VoIP configurations.
If you need an open NAT, please start by selecting your router company here and following the onscreen directions for creating Port Forwarding.
