Pse8: Elements Organizer “An error occurred while saving the project”
Hello, I am a user of Pse8.The following error message pop-up: Elements Organizer “An error occurred while saving the project”, when I try to save my slideshow using Save Project. This happens now removes the pop-up and “grays-out” the Save Project option on the menu bar when clicking OK. If I select File/Save As the same scenario occurs. What can I do to save the slideshow so I can work on it later? Any solution would be helpful.
Windows 7; 64-bit O/S; 9 GB RAM; 529 GB free HDD; Intel Corei7;
The network storage device w/ 2.5 TB free has the Photo library
Thanks
Answered By 0 points N/A #150861
          Software error is caused sometimes by some computer malware or virus. For you to solve that issue, just download anti virus and install it to your computer, after that scan your computer. If the error still occurs, try to check your installer. Install it to another computer and then try to do the process that you are doing to that computer. If that error still there, the problem is in your software.  Just try to do some way like that to know what really the problem is.  You can also try to run the program as administrator. Sometimes that error occurs because of computer policy.  Good luck.
