I use PTGUI Tools 9 for stitching multiple panoramic JPEG images on my iMac with 2.7 GHz Quad Core i5, NVIDIA GeForce Graphics Card and OSx Snow Leopard.Â
I have now upgraded to the OSx Mountain Lion and the program now crashes when launched.
Are PTGUI Tools not compatible with Lion?
Ptgui tools crashes on Mountain Lion
I don't know which version you are using but PtGUi 9.04 works perfectly on Mountain Lion. After upgrade some files may become corrupted so I suggest that you reinstall PtGUI and then you'll be sure all files are installed correctly. Make sure that you install most recent version of your application.
I hope I helped.Â
Regards.
