Ptimer Error on running php script on IE
 Hi dear,
I write PHP script now I want to execute this script by using internet explorer but it shows me error but when I try to open this script in Mozilla Firefox , Google Chrome then it works properly but I want to know its reason and want to know how can remove this error because many people use internet explorer and when they open this site they feel problem so please tell me how can I remove this error.
Ptimer Error
An unexpected error has occurred during execution
of the main script
ImportError: ‘/user/lib/python2.6/lib-dynload/PyQt4/
QtCore.so’ not found
                                                            Open Console              Terminate
Best Answer by Peter franklin
Answered By 0 points N/A #121774
Hello Rizky,
If you have not been able to fix the issue just yet, I will suggest that you uninstall the old version of Mozilla Firefox that you have on your computer and then install the newest version. Or you can just upgrade the browser instead of uninstalling and then reinstalling it.
Nicke
Answered By 10 points N/A #121775
The script is not running because, maybe you have the older version of the internet explorer and as far as chrome is concerned it is updated automatically that why it is able to run it. You will have to manually update internet explorer by downloading the latest version from here https://support.microsoft.com/en-us/help/17621/internet-explorer-downloads. And install it. I hope you find the solution.
Peter franklin
