Publication Incorrectly Printed in Publisher 2010
Try going to the settings. Check each and every option available to be sure that the application runs properly. If there seems to be no problem with the settings, try checking your computer for any possible errors.
Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like Norton SystemWorks or PC Tools Performance Toolkit.
These are great tools for investigating any errors in the hard drive’s file system and other problems in the system.
If checking your computer for errors didn’t help solve the problem, try uninstalling the application then install it back. This will fix any corrupted files in the installation and will restore the settings back to default. You also need to check the settings of the printer.
