I have a publish program and last day I received an publish error during publishing my project so I need your help to resolve this issue.
Error:
There has been a problem publishing your project.
Press ESC, Space or Enter to close.
Publish program showing error while publishing
Hi Vivian,
               There are instances that this can be a hiccup with the software you may want to try to make sure that all the parameters needed are in the correct location. If it is then, try to do a repair on the software as this rebuilds the problem for any missing functions. You can also try to disable anti virus software just for the time being as you are isolating the problem.
