Publishing AutoCAD to Google Earth model format
Posted on - 02/27/2013
Hi
AutoCAD is just so fun if you're into designing and creativeness. But I will like to do more and I have search over and found that I could publish AutoCAD to Google Earth! So I try to publish. However, I can't seem to publish the model that I did. Is there something I didn't do right? It just didn't work. I'm using AutoCAD 11 by the way.
