Pulse feed reader rss generator
Pulse feed reader rss generator: Do you know any forums about how to add the RSS feed for Pulse Reader? Please let me know if there is. Thank you!
There are some RSS forums on the internet. But the solution for the problem you are having may not available there. If you are using a valid feed sometimes the problem may be an issue in the Word Press. You may add RSS feeds by clicking on the yellow RSS feed icon located on the websites. It is the easiest way to add RSS feeds to your reader. But this solution may not help you much. I'll provide you some links to obtain help from some forum sites.
http://www.rss-specifications.com/rss-forums.htm
* The above forum site is related to RSS feeds. You'll be able to obtain all the related information about adding, subscribing etc to RSS feeds there. You may also get any solutions to your RSS feed issues from the forum available there.
http://www.dummies.com/social-media/linkedin/how-to-use-linkedin-updates-and-rss-feeds/
* The above site is related to Pulse Reader application. You may find solutions if you are having any issues with the Pulse Reader application from there. There you can find all the technical support as well as RSS feeds.
