I have windows 7 64 bit installed and trying to install Puppy Talk V. 09. How to install this S60v5 software under windows 7? If there is a way to install puppy talk in computer then any kind of help would be appreciated.
Puppy talk in computer won’t install under windows 7.
Hallo Jennifer,
For sure you can install Puppy Talk on your Windows 7 64 bit supported computer. The following is what you will need to do:
You will need to go online and then download Puppy Talk application that is 64 bit too.
Make sure that it is 64 bit to avoid compatibility issues.
After you have downloaded the setup, save it on a folder on your computer.
And then run the setup.exe to install it.
Nicke
The application you are trying to install is designed for S60 mobile phones and does not run natively on Windows computer systems like yours. You can try using an emulator such as the S60 5th Edition SDK. However, you must first install these two applications: Java and ActivePerl.
