Purchased Items on ipod touch 5th gen
I have purchased a music album with music video on my ipod touch 5th gen, where does it goes? Please help me with it.
Dear David ,
you can sync your iTunes
thanks.
You must he an iTunes. Install it in your computer and attach your iPod touch on it. iTunes will automatically search for the music library located in your iPod. This is where you should find all your purchased music. iPod’s protocol will save it there so it would be easy to locate. In case you downloaded the entire album, your music library will contain a folder with the name of that album. Refer to the picture below on how the music library will look like with iTunes.
Make sure that your computer detects your iPod. You will know this because a popup window will appear saying that it has detected a new hardware which refers to your iPod.
Regards.
