Purchasing a new monitor and setting it as the primary monitor.
30 points
Posted on - 04/10/2015
Hello!
I will buy Dell Ultra Sharp U2412M pretty soon. I would like to ask how much is now. What are the special features of this monitor/ what are the benefits of using it? If I am going to use this as my primary monitor, do I need to connect it to DVI port? Or I can just connect it with USB and use my control panel or display options to make it primary? Can you show me how to toggle between two monitors? Can you show me how to set it as the primary in the proper procedure?
Please accommodate my request.
Thank you!
