I have received a serious warning during installation of PureCM Client Development tool. It’s weird and can’t resolve this annoying error message. Do you have any idea to fix this issue? I would be grateful to you.
PureCM Client Warning
W0100 – Failed to merge file ‘COPYING2’ edit. Failed to find a common base revision.
PureCM Client Warning has occurred
Hi Carol,
This error means that it cannot merge an edit to a file which hasn’t been added. To fix this problem, you must merge the original changes that were added file1.text into Version2 workspace. And then, check the 'Enable Baseless Merge' checkbox. By this, the Resolve tool will allow you to choose the Version1 revision or the Version2 revision.
I hope this tip will help you.
Martine Paul
