Putting A Hyperlink In Word Document With Ease.
I needed to put a Hyperlink in Word document to refer to a link on the internet. I also need to put some reference to the folders as well. How can I achieve them without much effort?
Word creates hyperlink by itself if you just press Enter or Space bar after typing the link or the address of the webpage. You can create hyperlink even to the files, email addresses, and even location. Select any picture or text to display as hyperlink. Use Insert tab to open the Hyperlink and type the address in the Address box. Similarly, you can provide the location of the files on the same dialog box. So, hyperlink is effective way to make a powerful Word Document.
