Pv inverter error with assistant trying to correct hub2
Hub-2 assistant tried to correct frequency shift for connected PV Inverters and during the process this error message appeared and nothing happened after I pressed the OK button. I would like to know what error were created in my PC because of this error ? Can any expert tell me please ?
Thanks !
Error
Self-consumption Hub-2 v2:
‘The PV Inverter support assistant cannot be used in combination with the Hub-2 assistant. Please note that the HUP-2 assistant will correctly handle frequency shift for connected PV Inverters.’
