QMax exporter error message while exporting the contents
I work for a 3D animation company. I use Q MAX Exporter to export scenes for the QServer (used by the Qube game architecture). After exporting into QServer format file, it can be used in QStudio to author the complete game scenes.
I installed it on my Win 2003 SP 3 server using the supplied windows installer package and rebooted the server. The installation was Complete and successful.
I initialized the exporting process with the Q Exporter with the options Export without textures checked and applied scaling factor of 1.0. At the end of the export a warning message popped up with:
“O errors and 5 warnings were logged during export. Do you want to view the log file? “
Have I done something wrong in the exporting procedure? Do I need to change something so I do not get these warnings?
Best Answer by Clair Charles
Answered By 0 points N/A #85490
It seems there is no any problem with your installation. You have setup software successfully in you computer. Picture itself says 0 error and 5 warning.  You have to click on yes while this pop up message comes.
You have to see log file  and correct  some parameter  which is wrong during export process  that correct it after you will never see this option. For more detail you have to paste your log file so exact problem resolution you will get.
Thanks
Answered By 15 points N/A #85492
You have not done something wrong, but there are actions that may have been taken the application may just be cautioning you about which will not affect the performance of the system but it will be better if you did them is some other way.
And therefore what you should do here is click Yes on the error message window so as to open the log file and see what the warning are about. In case it is something that may influence the performance of the system then you will need to fix them.
But since they are just warnings, they should not affect the performance of the application or the whole system.
-Clair Charles
