QSYSOPR Message Queue on my Test & Production System
My test system has a different IP address as to my production. I am getting a QSYSOPR message queue from my test system to the production system. How can I fix it?
You will need to ensure that monitoring system has been set to ignore any severity that is 81 or higher error messages which may come from the QSPLJOB user. The QSPLJOB user error messages will in most cases indicate printer messages, some which will include printer out of paper, check printer alignment, and also the change form type. So you may need to set up your monitoring system so that it will be able to only check for critical messages during off-hours, and you have to know that doing that will quickly inundate you with messages in case you send out alerts for standard printer messages.
-Thompson Locker
