The quality of my dell laptop fan speed.
Hello experts,
The quality of my dell laptop fan speed.  As I was observing my dell laptop for almost 5 months there are times when I use it for business purposes it goes too hot for a minimum of 4 hours of use. Well I am just wondering if this is the temperature level that a dell fan speed can do.
Thank you.
Answered By 0 points N/A #185146
You may search for the solution for your laptop heat. It may be the cause of the environment as if it doesn't match with yours. I would suggest getting a cooler. I recommend a cooler that has two attributes:
1) Active fan
2) Metal
Both these tools LL helps to overcome the heat of laptop and give you a comfortable environment as you need.
Those are my personal Opinion, i recommend you the following Url for more solution.
http://www.diefer.de/i8kfan/index.html
https://www.dell.com:443/community/Dell-Community/ct-p/English?profile.language=en
http://cdiefer.proboards29.com/index.cgi…
