I have installed QuArK 6.6 Beta and I think I have configured it properly. Now when I try to run it cannot find the Hal Life and this error comes on. I don’t have a lot of knowledge working with QuArK so I am having some problem to solve this. Can anyone help me to reinstall it properly and tell me about this error and why I have it ?
Thank you !
Error
QuArK needs the file materials/Dev/dev_measuregeneric01b.vmt’ from Half-Life2 (directory ‘C:Program FilesValvesteam/hl2’) and could not find it. You must set up the correct path(s) to Half-Life2 in the Configuration dialog box.
EXCEPTION REPORT
QuArK 6.6 Beta Address in the program 00547A28 (005350E8)
Please report this error to the QuArK development team, so that they can fix the issue promptly.
QuArK needs the file materials from Half-Life2
I don’t see any problem regarding compatibility issue when using QuArK 6.6 Beta because it is compatible with any Microsoft Windows operating system. The oldest operating system where you can run it is Windows 95. Since the error is about a missing file, try finding the file in the indicated location in the error message.
Open Windows Explorer and go to “C:Program FilesValveSteamhl2”. Search for the file “dev_measuregeneric01b.vmt” supposedly inside the folder “materialsDev”. In case the folder is located in a different location or the missing file is found in a different folder, run QuArK again and specify the exact path of the file “dev_measuregeneric01b.vmt” in the configuration dialog box.
If the file is really missing and can’t be found in any folder, try reinstalling Half-Life 2 and then check if the file is restored. If the file is still not there, you can try either reinstalling Steam Client or update it to see if the file can be made available. If you wish to download QuArK again including the recent available patch, visit QuArK 6.6.0 Beta 6 with Python 2.4.4.
