audreyreed
430 points
Posted on - 10/28/2011
I have lots of questions and I am seeking for someone who can help me resolve it. To start with, I am having problems with combining text with images and then moving them both at the center. When I clicked on the Center sign, I am having no result. How can I do it? Secondly, I don’t know what color I should use since the color has codes that I hardly understand. How will I know if I am using the right color I intended to use if the color has codes? Lastly, how can I make my paragraph lines and spacing consistent and efficient? I hope someone here can give me a little time to answer my queries. Thank you.
lee hung
75 points
Queries on combining text with images
Hello Audrey,
To combine text and images together and move them, I will advise that you use the selection tool which you can find in the main menu of the word document, select all the text and images and group them together, then move them. In your word document, you should see an icon with the text 'select', click on it to activate the selection tool. Then go to the text and images and encricle it with the selection tool, and then group then right click and then choose 'group'.
Press CONTROL+C on the keyboard to move the text to the center, but first make sure that you have highlighted it. If you have turned on the SHOW/HIDE feature, disable it in the word document main menu. It could be the one bringing problems when it comes to making your document centered.
__
Regards
Lee Hung
