Queries on using Apple GarageBand
Hello Experts!
I have a simple query about GarageBand of Apple. And I hope that you will not use too technical words in stating your replies, as I am not very techy person and I only know a little about technology. Here are my questions:
a) How do I transfer my GarageBand in a storage device?
b) When I played my garage band recording using my headphones or my iPad, it played smoothly. But when I attached it into an email and tried sending it to myself, a high frequency sound was emitted in the recording.
How did it happen?
Thank you in advance.
Answered By 0 points N/A #100457
To get to save your GarageBand on a different location you need to open it then in the pop up window click create New Podcast Episode. Then enter a file name for your recordings choose a location on your file then click create. On the left side of your screen click the icon for your voice that is male/female voice. Move to the middle of the screen where there is the track recording button and when you are ready to record click and record your voice. to listen to your recording drag the play cursor back to the beginning. When you are finished and satisfied with your voice click share. I hope that this answer will be of much help to you if not clarify exactly what you wanted.
