Is it possible to export database in Reportizer?
What kind of documents are compatible with it and is there a specific requirement in exporting each database according to their file types?
Step-by-step instructions would also be appreciated, especially with RTF formatted files.
Thank you.
sourov13
Query about Exporting Database with Reportizer
Yes it is possible to export database in Reportizer. Reportizer is a band oriented database reporting tool.
Creating database report Reportizer is simple. It has all you need  to build and print report. Reports can be edited in convenient visual report designer with powerful property inspector and tool bars.
For advanced users, there is an option to modify reports in text mode. Reportizer works with relational databases via BDE or ADO. It has been tested on dBase (DBF), Paradox (DB), TXT, CSV, Oracle, Interbase, MS Access, MS Excel, SQL Server, HTML, Visual FoxPro, MySQL, PostgreSQL. Database queries are written in convenient SQL editor with syntax highlighting and code completion.
Report generator supports dynamically calculated expressions, displaying images, grouping, calculated fields, multi-column reports, totals and subtotals etc.In addition to database reports, Reportizer can build and print file reports. In this case, Reportizer uses Windows file system as a database, where folders are tables, and files are table items.
Using such a feature, you can print list of files from specified folder(s) (with their icons, dates etc.).
