Query about a new repackaged Winstar Router
Hello to everyone. Does anyone knows or has the same similar issues which can help me resolve my problem? This is the situation:
I bought a new wireless router, a repackaged Winstar from Monoprice which I got from this site:
https://www.monoprice.com/StaticContent/HttpError404?aspxerrorpath=/products/pr…seq=1&format=2
I am taking risk at it since it is just a repackaged product with no instructions included. I will use it as a bridge to connect it to my Linksys WRT54GL which runs on a Tomato 1.28. I also purchased two 9dBi antenna extenders to attach it to the Winstar wireless router and because there are no instructions or manuals included on the package, I needed help from Monoprice Technical Support Group and they helped me so I was able to set it up as an Ethernet Bridge. From this, I saw no noticeable differences in its wireless connection strength for my three small bedrooms at home with concrete walls between the two routers. Honestly speaking, I do not think wireless bridging is enabled but maybe I could have been mistaken. I want to use my newly bought router without having it to send it back and buy a new one from Linksys. Thank you and much help will be in support.
