katie bruce
Posted on - 12/04/2011
I am creating a XenApp 6 environment and I need help on printing servers and Universal Print Driver (UPD). How can I make my Citrix Servers use UPD in the farm? If I will use UPD, do I need to make Citrix server as my print server? And also, is there an issue if my driver is 32-bit or 64-bit? Will it affect the UPD if I will be using x86 or x64? We are using two server for printing, we are currently using x64 PS Citrix Server and x86. Ani deas on how can I fix this? Thank you.
Query on Citrix Server and UPD
When using UDP, you will find that it is more efficient, and the reason to that is because it does not check packets for integrity or correct transmission errors IMO, When running an NFS, it will simply share without any integrity checks.
There might be as losses as high as several percentages when using UDP, but that will depend entirely on how good your network connections are. You can make changes to it but that will be at your own risk.
What I will suggest that you do is that you should try adding manually to /etc/mtab something close to the following line:
server:/us
r/local/pub /pub nfs rsize=8192,wsize=8192,timeo=14,intr,udp
See if that helps.
-Thompson Locker
