I usually see domains with a setup welcoming anyone on logging in and then make some complains to the Admin's Group under the domain afterwards. Now, I want to separate the Admin to their own group. Particularly, there are users that needs permission on assigning the web pages to the web servers and validate SQL with the Windows verification within the SQL Server users and more.
What I want to know is, if there is any unique steps to begin this method and design an efficient and protected settings with different attributes of IT admins?
Query on separating Admin to their group on a domain
With the information provided I believed you will be able to see the document, the Freedom User's Guide identifies the features and you can use your Freedom server to host a single Web site, or many different sites. Web, mail, and FTP services, SQL databases, Windows-compatible network file allow you to run Internet server applications the way that they were designed to be.
If you are using visual studio 2010 then in that case you need to use the windows authentication. You need to use the steps related to windows authentication. These days, a new trend has started and that is of SSL. This is extra protection to authenticity of the website. You need to implement the SSL as well. Hence, in that case the user will first have to verify the certificate and then he will have to enter his windows password and user id. Only then he will be able to login to the website finally. Hope this will solve the problem.
Waters Magner
