Question about the bijoy keyboard
what is the difference between classic bijoy and unicode bijoy?
which is used better?and why?
which is more easy?
which is more easy?
Hi
To whom it may concern
The classical bijoy is bangla writing software which has been used for last decades. most of the media/newspapers writing choice is this classical bijoy. Even if you go to bangla software, most of them are from classical bijoy.
on the other hand, unicode bijoy is a program of Unicode. it is newer technique and i would say it is much easier than classical bijoy. Key layout of classical bijoy is very difficult to memorize. on the other hand, it is very easy to use unicode bijoy.
That is why day by day the use of unicode is increasing as it is newer in terms of technology and acceptance.
for better suggestions, i would recommend to use OVRO unicode.
hope this helps
