Emails being sent under my name
I have a problem. Emails are being sent to my email address. These emails came from contacts or people I don’t know.
Has my account been compromised? I just did a clean install of Windows 7 today and no virus has been detected on this install and on last one. Can anyone clarify this to me? Thanks.
Best Answer by curtiende
Answered By 0 points N/A #95341
Hello Lauenhensen,
This is nothing to be worry about. Apparently, your account has been compromised. I recommend the following:
  • Install a malware program and change the password immediately. The new password should be strong.
  • You have to check the information of your account, if there are any changes happened. If you found any change of information, correct it.
  • Ask all contacts in your list if they received any mail from you. Tell them they may have the same problem.
  • Finally, contact the service provider of your email.
Answered By 0 points N/A #95342
A strong password is your first line of defense against intruders and imposters. Here are some few tips:
  • Never give your password to anyone.
  • Try as much as you can to use different passwords for different sites.
  • Create passwords that are easy to remember but hard for others to guess.
  • Remember that the longer the password the better.
  • Include numbers, capital letters, and symbols when creating your password.
  • Consider using a password manager.
  • Don't fall for "phishing" attacks.
  • Make sure your computer is secure.
  • Consider a “password” for your mobile phone too.
