A question about flash presentation backgrounds. How can I add some fading effects in my website banner background? Do you have some special codes for fading backgrounds? I want to attract online viewers in my forum so that they will be able to post and participate.
Waiting for your support, thank you.
You should install Flash Player 7.0 for you to be able to review animation during the creation of animation. Install also the Flash MX application in your system. This application will make the fade in fade out that you desired to put in your website. For complete and step by step creations of fade in fade out you want, visit the link below.
http://www.entheosweb.com/Flash/fade_in.asp
How to insert flash files into HTML codes.
