A question about how to open an album in zip format. I am very interested to know the important details in opening a zipped format. There are some steps to be followed before we can finally open a zipped file format. Can you give me some ways to open an album in zip format?
Waiting for your support.
Hi Debra,Â
I think I can easily solve your query, what you need to know most important about zip files is that the files need a software to open. In this case, the software you need will be a zip software such as 7-zip.
Go to http://www.7-zip.org and download the software.
Once downloaded, follow the prompts and install the software.
After installing the software, you can select the zip archives you want to open, right-click on them click on 'Extract' and select the folder you want to extract to, your zip files will now be unzipped and ready to use.
I hope this solves your query.
You can use WinRar to decompress RAR, ZIP and other file format. First of all, select the correct version and download WinRar from the link below:
https://www.rarlab.com/download.htm
Once the downloading process is done, you can double click on the exe file to install it on your computer. And if WinRar is already installed on your computer, you can just right-click on your zip file to unzip it. Click Extract files to open the WinRar zipped files and then just click OK until the process is done.
