Question about jMP compile and Nifty Gui
I am creating a Windows application using jMP and I noticed that when the app is run from the distribution build, Nifty Gui is invisible. It renders through the jMP though. Why is this so?
Hello Ludwig_porter,
I will suggest that you try restoring the application's fonts to default in case you had changed and see the difference it brings. You may also try raising the maxForce and see if it will solve the issue.
If that does not work yet, I will suggest that you try setting the maxSuspensionForce parameter which you will find in the properties editor for the Vehicle Control. But in case you will want to set it using the code, then you will need to set it for each wheel.
You can also visit here and see if you may find more help from there in case the above solutions have not worked yet:
Hope this helps.
__
Regards
Mahesh Babu
