Question About Keywords and Keyphrases
Will Google consider punctuation mark when it reads keyword or keyphrases (SEO purpose). For example; crime scene clean up and crimescene cleanup. Will that be read by Google bot as the same key phrase?
Hello Ceana,
Yes it is. If the keyword or phrase will be use in the sentence for several times, it is automatically be visible when someone search for it. The widely used method in the invisible misspelled keywords but not suggested. Applying cloaking text techniques could be dangerous to apply; some search engines may flag or even forbid your website for such things.
The dilemma would be that if a visitor selects that text by mistake, he would see a few rows of misspelled words on your site, which indisputably gives a negative outlook to your professional image.
I will leave you a couple of advises about keyword and key phrases. You should pursue on making a good keyword, make it related to your topics, key phrases must be enough (not too short, not too long). Make it Simple but catchy.
I hoped this helps.
