Question about the Query Languages
Why not use a Structured Query Language (SQL) and / or queries from X to Resource Description Framework (RDF) files query?
Why does it need to enhance a new query language?
And how fast I could work the task item from an email?
Answered By 0 points N/A #138641
A new query language is designed to make it easier and friendlier to occasional users. It is good news that the designer of this said system has improved so that those occasional users who try to use complex databases need not spend too much time studying and learning for hard command languages.
There are disadvantages when you use the Structured Query Language. One is that it is hard to integrate with SQL queries in database applications. Another is that it produces inefficiency because these data has to be converted from SQL to its assigned data format. So, it would be easier and efficient for you to use new query language because this will result to less graphic presentations in your emails.
