Hey techyv,
I recently downloaded and installed sntp for windows. However the serial number I have is for an older version of sntp for windows. I am just wondering if the serial number I have will still work for this version of sntp for windows or if I need to get an updated version?
A question about serial numbers for Sntp for windows
Hello Michael
It is possible that sometimes, serial numbers for older versions of softwares are compatible with newer versions. In this case it is most likely that the serial number you have will function.
If it does not, you just find out what version of SNTP you have installed, and get the serial number for it.
I hope you find this information useful.
Randolph
Talking about serial numbers, they serve as your license for a particular software product. It unlocks the full features of an application. Normally, when you buy a license for a particular software product, the serial number or license key is valid only for that particular version of the software. It may also allow you to install future updates.
Your license also may or may not allow you to install future releases. Updates and releases are different things when comes to software. An update refers to higher builds but on the same version. This can happen when the developer applies the bug fixes and enhancements on a particular version. A release means a new version.
This is the version that follows the existing or current version. If you want to install a new version of the software, check your license if it covers new releases. Sometimes a license is applicable only to one version.
